Along with a lot of others, I wish there was a little less gap between the tires and the wheel wells. I'd actually prefer not to lower the car as the ride height is perfect for my steep driveway. Also, when lowering the 3 it shrinks the gap above the wheels, but it leaves a large gap in front of and behind the wheels, and to me that inconsistent gap is even worse.
What I'd actually prefer is if there was a way to mount 19" or 20" wheels with an extra .5-1" of sidewall so that it filled the space evenly. The problem with this is that the speedometer and odometer will then read lower than they should.
Is there any provision to correct speedo readings if you put on tires with a larger outer circumference?
