Yeah it's just plain weird. Bizarre operating system. At first I thought maybe the 16 amp draw was rebalancing because sometimes the battery shows discharge when it's rebalancing. But clearly in this case it's not it's just being drained. I realized also it probably could not even be cabin heat because cabin heat is running off the main pack. In any case after resetting and recharging, the battery is now showing an overvoltage error at 14.2 volts. I'm wondering if the system overcharges the battery, then the battery management system prevents charging which it does when you get over 14 volts, and then the operating system rejects it and then drains it. It's f***** up whatever it is. As I mentioned before we had a similar bizarre and unexplained failure of the 12 volt system in our power walls in Florida with disastrous consequences. Tesla does not know what the f*** they are doing with 12 volt systems. Sorry for the bad language but this is just ridiculous.Instructions above on how to do a reset via the app and clear the warnings. I haven't tried it as I still have a V4 with the (+) coming in a month. Very odd why a 16 amp draw while parked with major draw items off. It's like the system spots a battery it doesn't like and tries to drag it down to failure to set off a warning. Like you, my V4 was working very normal for almost 4 days then all of a sudden the lockout occurs and it starts to drag down. I spotted it in short order and intervened before a dead battery. Now, it I had the V4+ and I got the change battery warning from the Tesla app, I could (I guess within bluetooth range) reset. Not sure how long that would last. At this point, ALL the lithium manufacturers should corner Tesla for a working solution since more than just Ohmmu is now affected.
PS has someone confirmed that this power cycling recommendations as posted above obviates the need to disconnect the dc/dc connector under the rear seat?
