israndy
Supercharger Hunter
That is what we are trying to figure out. Perhaps we need this thread turned into a Wiki so we can keep a data sheet in the first post
Elon closes on Twitter on the 28th. Ohmmu petition auto generates a Twitter post. Bottom line, it's a 12 volt battery. What difference does it make on it's chemistry or slight voltage variances. Put a voltage regulator from a 68 Ford would probably work better.My errors always happened a day or two after a trip. I was in Canada for 4 days, and my trunk was opened as I left the house haha. But I did not get a message on my Tesla app about replacing the battery, so I don‘t know exactly when it happened. But when I got to the car I had 3 errors and 10% SoC. And both times I’ve been under the 15% SoC that Ohmmu stated. I’ve yet to had the issue while using the car unlike my first ohmmu which happened while I was driving and my screen even went black for a second north of Spokane WA.
I was use to having to disconnect the HV feed in order to remove the errors, but if the new reset procedure clears them thats cool.
I’d be all for pinging Elon too haha but that is a tough needle to thread. Almost need to get a few others in the community behind it. May need to spot YouTube to see who was making Ohmmu videos and run that up a flag pole.
Yes and all the earlier trolling on this thread (which thankfully has disappeared or at least abated) obscures the fact that almost every other single vehicle from basically all the other auto manufacturers has no issues when you replace the 12V lead acid battery with lithium iron phosphate, largely because their float voltages and maximum charging voltages are so close within basically a tenth of a volt or so. Only Tesla has issues, and again it's worth remembering that these only started last Fall when they started monkeying with the charging routines (and we have to presume that included the insertion of a very problematic desulfation routine).Elon closes on Twitter on the 28th. Ohmmu petition auto generates a Twitter post. Bottom line, it's a 12 volt battery. What difference does it make on it's chemistry or slight voltage variances. Put a voltage regulator from a 68 Ford would probably work better.
For whatever reason that is one update that's been on my radar for a while and just refuses to hit my car. Hopefully no issues with the battery after that oneGetting 2022.36.5. I’ll give this a shot again this weekend.
I’m not sure on how the cadence works. I know with my battery failures or if I’m on a road trip off wifi I normally have to manually hit Software in the car to get it to check. It worked yesterday night that way. I saw others getting 2022.36.6 as I was just getting the .5.For whatever reason that is one update that's been on my radar for a while and just refuses to hit my car. Hopefully no issues with the battery after that one
… and now its downloading .6 hah!
Just for clarity, was this the reset procedure you used that didn't work? Curious what the "MOS lock in" means as well.My v4+ finally decided to tick off the Tesla LVB logic (or lack thereof). MOS Lock in. Whatever that means.
Same exact symptoms as those who posted above before. Multiple VCFront alerts and once they set, the car proceeds to drain the battery @13A, down to @6A and fluctuates between tbe two.
Without taking action, and with those VCFront alerts set, the battery will drain from full (where it was) in a matter of 4-7hrs, at most 15hrs (at a lower draw).
The only way to stop it:
More permanent and prevents the drain
(which with the codes set will continue while using the car, tanking your efficency).
a. go through the LVB replacement steps (without actually replacing the battery) to clear the codes - discharge stops and v4+ happily goes back to working untio whatever triggers the codes happens again.
Short-term bandaid to get back home or prevent same-day drain
b. when the car is NOT being used, parked for shorter or longer periods, set the discharge enable to off to prevent the drain (and make sure to put back in befote using the car).
The Ohmmu v4+ reset procedure didnt do a thing in fixing the drain or clearing the errors BTW.
Also note, any recent update is irrelevant to this issue happening or not. An ipdate dowload or post update diags can trigger it but so can prolonged use of 12V while stationary.
It can and will rear its ugly had with anything from 2021.36.x to 2022.40.x since they all contain whatever logic the LVB dev/s puy in since mid 2021.
When it triggers is just a question of time and individual car setup, accessories and use.
I did notice that when the errors set in the car, the Ohmmu app shows only one advanced page error:
MOS lock in.
I shared all this with Sean as I bet many of you did.
View attachment 868934View attachment 868936View attachment 868937View attachment 868938
I have noticed when I do a battery swap and power off the car in the safety menu, it takes about 5 minutes to be fully off. I will have footwell lights on until that happens.I was 'lucky' in seeing the VCFronts set exactly as I was exiting the car after that 40-50 mile drive. So I saw what was happening (short of what triggered it) in real time.
a. got to car in the early morning, after a 48+ hr deep sleep, no issues, Ohmmu at 100 % SoC, car woke up and worked normal
b. drove 40-50miles with heater on/off, car audio on/off, phones wireless charging on/off, usb recording camera feeds
c. stopped, stay in cae for a few minutes
d. exited car, before I closed all the doors Tesla app alerted about VCFront errors setting.
e. opened Ohmmu app, saw the suicide discharge starting to happen, Ohmmu SoC starting to drop.
BTW for anyone that wants to test sth else, here is a new check from Sean:
Does the car turn completely off when you do the following:
In app: disable charge and disable discharge
In MCU: under safety/security select and confirm "power off"
Then wait about 30-60 seconds; don't do anything else and then press the brake pedal, does the car remain "dead" or does it wake back up at that point? (don't enable the 12V before pressing brake)
For me the car remained dead/off.
Did this issue occur after the latest SW update or some other change or none at all?I was 'lucky' in seeing the VCFronts set exactly as I was exiting the car after that 40-50 mile drive. So I saw what was happening (short of what triggered it) in real time.
None at all, BAU driving around with previously installed firmware update from a good while ago. As I mentiones above, whatever triggers the errors is embedded in all post 2021.36.x firmwares so whether you are on some recent FSD beta build, 2022.28.x, 2022.36.x or 2022.40x makes no difference. Only a matter of time.Did this issue occur after the latest SW update or some other change or none at all?
Yes. Same here, footwell, door cards and interior lights, sometimes even useful to leave the fan on 1-2 to hear it disengage, re-engage.I have noticed when I do a battery swap and power off the car in the safety menu, it takes about 5 minutes to be fully off. I will have footwell lights on until that happens.
