Looking for 12V under Frunk
I’m installing a set of laser shifter. Last step I need to complete it is to tie in 12V power. My car is a 2023 model and have the lithium ion battery.
I’m lost as to where to grab it from, any advice would be greatly appreciate.
Solution
Where did you end up getting the 12V for this?
I found a pic of someone bolting it on directly to the positive stake. You will need a really small nut and bolt. I used the smallest bolt on this kit. https://www.amazon.com/gp/aw/d/B0BN297MP5?psc=1&ref=ppx_pop_mob_b_asin_title
It should be a M3 size bolt that I used. I had the wire running down instead of left on the pic. The plastic cover did fit ok afterwards. Did not seat completely but enough that I felt comfortable.
Reactions: Kwame
Upvote 0
Thanks. May I ask which system you went with for your install?
Upvote 0
