Looking for a US 2021Tesla Y, CCS2 Retrofit kit for the EU
Hey - I actually just went through this with my 2018 US model 3 that I bought with me to Europe. In my case I needed to update the charge port ECU to v4 to get ccs adapter support enabled.
After doing that, I bought a CCS2 to US TPC/NACS (Tesla proprietary connector) from evseadapters.com. Unfortunately, the adapter won’t work out of the box unless you have a EU charge port ECU so I had to modify the adapter to add a 160 ohm resistor between the PE and PE contacts.
After doing this, my car can charge at all CCS2 charging stations but not at V3 superchargers.
Reactions: Joe Wang
Curiously, if replacing the ECU with the PN:1537264-20-B EU instead of 1537264-00-B US, will Tesla CCS2 V3 SC be supported while using the same adptor or the one shown below, which I guess the resistor is built-in and can be toggled by switch
