Hi everyone,
M3 SR+ (2021) owner. 22k miles. Never had issues with the car, never needed service support.
Over the last couple of weeks my alerts have been showing the same 3 issues popping up daily. They are not causing me problems with the car but I am just looking for advice to see if I should do anything about them or do I just accept that they will keep popping up and are no big deal, (Assume that perhaps future software updates will fix). The alerts are:
Any and all advice gratefully received
Cheers
- CP_a051 Charge port may not open when pressed (Use another method to open the charge port)
- This has appeared in the past but generally resolves itself (I assume due to software updates)
- UI_a045 Emergency call is not operational (system error may clear on next drive) and UI_a161 Emergency call temporarily unavailable (Check cellular connection if issue persists)
- I assume this is to do with cellular cover but its odd that it has just started to appear recently
- UI_a112 USB device malfunction - I/) Error (Unplug device from USB port)
- I assume this is to do with the Tesla USB stick - I have formatted, deleted all dashcam footage and unplugged + plugged back in
Cheers
