mobile service, homelink, heat pump cover, B pillar
Discussion in 'Model Y: Interior & Exterior' started by floydturbo, Aug 2, 2020 at 8:10 AM.
  1. floydturbo
    floydturbo Member
    sacramento
    I had a mobile service to install the homelink. After I made the appointment, I edited the service to install part number #1502213-00-A ac compressor acoustic cover and that the B pillars had a gap. They actually ordered the heat pump cover and installed it at the mobile service. The technician who had been with Tesla since 2012 had never installed one. The instructions he said were to remove the refrigerant and remove the in and out lines to install the cover. We both said NO. He cut a couple of slits in the cover and was able to install it around the ac compressor. Also, the B pillar clips were not holding. He had some different ones in his service car and replaced 3 clips on the drivers and passengers side and that seemed to work as the clips stayed locked in place.
    My heat pump was not really that noisy, but you could hear it. Most of the noise was coming from the fan. After the acoustic blanket, the compressor is nearly silent. You can still hear the fans for sure, as before.
  2. jeffbco
    jeffbco Member
    Austin, TX
    What was your build date?
  3. floydturbo
    floydturbo Member
    sacramento
  4. Flybuddy
    Flybuddy Member
    Fort Myers FL
    Thx for the info, I've got a tow hitch and homelink mobile service set up for 3 weeks from now. I also wanted to add the acoustic heat pump cover to that mobile service. When I go in to modify service it won't let me add it and wants to set up a new service center appt. How did you do it?? thx
  5. jeffbco
    jeffbco Member
    Austin, TX
    Other than noise and visual, is there any other way to determine if the acoustic cover has been installed?
  6. floydturbo
    floydturbo Member
    sacramento
    You edit the existing appointment and just add notes to it.
  7. Gigaron
    Gigaron Member
    San Francisco
    ROFL - The first digits are the most important and you normally leave off the last 1 to 3. Too late now.
  8. maximus96
    maximus96 Member
    Bay Area CA
    makes sense that may 2020 build is in the 9000s. My May build is 101xx
  9. Gigaron
    Gigaron Member
    San Francisco
    I don't have it in hand so I don't know the build date, but my Blue/White/AWD is 324xx. Did they really build 20,000 cars in 2 months?
  10. Flybuddy
    Flybuddy Member
    Fort Myers FL
    Mine is a May 20 build date with the last 5 on the serial number of 065XX
  11. Za_c
    Za_c Member
    Mine is very similar.
  12. HeyEph
    HeyEph Member
    Fairport, NY
    When I try to add an additional service to an existing appointment, it bumps my appointment date out to the next available. Is there a way around this?
