I already setup an SC appointment as it is the obvious thing to do in this situation... but I was wondering if anyone has had similar problems. Exterior temp was about 65 degrees.
Since I got the car I have been using my wall charger and charge daily to 70% or 80%. When charging to these percentages, I noticed I was slowly losing range. Today i have about a 10% range loss at these charge levels.
I decided to charge to 100% at a supercharger to see what mileage I would end up with and balance the battery. I charged from 6% to 100%. The car was stuck at 280 miles (100%) on calculating for over 40 minutes... I ended up unplugging when the charge rate was showing 1kW.
On my way home I noticed the mileage indicator wasn't going down (stuck at 100% AKA 280 miles). It took about 20 miles of driving for the range to drop from 100% to 99%.
See the following link for some pictures I took showing the above with timestamps (sorry for the bad quality).
Model 3 Battery Range Issue
I continued driving to deplete the battery down below 80%. I ended up in my garage at 77%... plugged in with limit set to 80%. A few minutes later I get a notification that charging is complete. Now the weird part is that maybe about 30 minutes later, I get a notification that charging has started again. My phone, was showing the car at 75% and charging! It finally finished charging (again) to ~80% / 223 miles of range.
