Anyone know the inner diameter for wheel spacers for this hub? I’m trying to get aftermarket wheels with 72.6mm center bore and I need a dimension for hub centric rings or a spacer to make it work. thanks!
Do you have the performance upgrade package? If so, you'll need custom rings made, or the wheels will need to be machined to fit.
If I'm not mistaken, the hub on the Model 3 is 64.10mm.
Yes, I bought aluminum 73.1 to 64.1 hubcentric rings. I got a Machine shop to mill out 3mm x 6.97 from the back of hubcentric ring I bought for my wheels.
