I also noticed it this morning when the heating element kicked on for the first time. Faint burning electronics smell.
Yes! Did you just get your windows tinted?
Yes, there is an odd, new car/something burning smell. I'm hoping/expecting it will go away after some usage.
Also, I've noticed that smells from items in the frunk seem to leak into the HVAC (spicy takeout food in the frunk)...I suspect the rubber seal on the frunk to the hood isn't perfect.
There is a vent between the trunk and the passenger cabin so you will definitely smell anything you put back there.Wow I haven't checked my trunk and frunk yet! That sucks
I thinking you may be right because I just got my windows tinted as well and that's when I noticed that smell. Do you have any ideas on fixing it or is it stuck in there for good?
You have probably solved this, but I wiped down my inside glass with some Perfect Glass cleaner and that cleared up the tint chemical smell,.
HOWEVER. My vents now smell like vinegar when the car starts up. Similar symptoms to what I used to get in my Model S that eventually turned pretty nasty smelling. To the point where after numerous service center visits, I took matters into my own hands and applied a cleaner directly to the heat exchanger via the condensation drain.
So I am resurfacing this thread from the dead. I have asked Tesla to look at it and change out my cabin air filter at my mobile service visit next week. Bonus, I maybe get to see where said cabin air filter is.
I really hate cars that do this. And with the car running AC when it gets hot in the parking lot, I can't control it in the "normal" advised ways.
What did you figure out about this? I have had the same thing, but just thought it was something I had in the trunk. It was not. Noticed the other day that it seems to appear just as the hvac fan kicks in shortly after I get in the car.
Just started having the vinegar smell issue myself. I’m diligent about running the fan on, no AC, before parking the car to try and blow the vents and AC dry, but it still happened...No solution yet. The service center ran a deodorant thru the system and said the new firmware (with cabin overheat) would fix it. It didn’t. It is just worse now. I will have to take it back in.
any resolution to this smell issue. I have it too. I notice it for sure any time it is humid outside. but other times as well. It is noticeable. Musty smell.
I’m having a smelly sock smell coming out of my model three, I live in Palm Springs so it is not a moisture issue. Just stinks for the first minute or so when turning on the AC. Wondering if others have the same ?Yes! Did you just get your windows tinted?
Has anyone been experiencing a weird smell in their model 3 when the HVAC is turned on?
