What equipment and lubrication do you require to do the job? Just got a Model S with a sunroof, so looking to take care of it.
Well, since I have the glued-on type of panels, I can't remove them to gain access to the whole track.
So based on some videos I've watched on YT (highly recommend prior to any DIY), I open the sunroof to about 30% I think, and that will allow access to the screws holding the glass panel on. I always slip a folded towel between the glass and the roof on both sides.
Once the glass panel is off, it's basically just you, a bunch of Q-tips (or small pry tool), and even more patience. The shape of the tracks where the sunroof panel moves has two recesses on each side, so you're looking at 4 total grooves you want to get clean. I either bend the tip of the Q-tips, or use a 90 degree tipped tool and wrap the tip with garage paper towels or a thin rag. Rewrapping a pry tool after each swipe is a real pain and time consuming. Q-tips are cheap, so just keep a trash can close and use a bunch of them.
Either way, it's tedious work. But necessary if you want a smooth, quiet sunroof.
Here's the owners manual link:
Correction Code 24100105
service.tesla.com
As for the lubricant, it says to only use the Klubersynth
RA 44-702 noise reduction grease (
for plastics).
I tried to use graphite powder first, but either I didn't apply it right, or it just doesn't work. So I broke down and paid over $20 for a very small tube of Klubersynth. I haven't had the chance to use it yet. But I'm only going to put it in the trouble spots and let it spread mechanically.
