Model X posible camera malfunction
Hi, currently on a long road trip, problem is after a self car wash i got 70% of time car is blind, it won't see trafic arround. As an example i would post some photos .
Did both reset soft and hard won't work, also dash cam got malfunctioned
Well, that's a new one. AP isn't available in any of your images, either. Everything you're showing should be the center camera set in the windshield. Maybe check the surface right over them? pull the housing and check the plug is tight?
Ap works fine as long as there are no vehicles on the way, it see the lanes, but having problems dectecting ( trucks flickering into cars or even to an empty space) but when wehicle would disappear it's trying to accelerate, I'm just not using autopilot atm while problem is arround. Thx for recommendation, tomorrow gonna try. Windshield is clean for sure
Possible root of the problem wich I found is upper panel from windshield, there is a buch of connectors and optical cables, and seem like panel is responsible for keeping them in place, now gotta see wich connector got loose
