If you navigate to a supercharger as you drive, at some point the car will start heating the battery. It will depend on your distance to the SC and when the car thinks it needs to start heating to make it there at the right temp. If you have only one motor, it won't be able to do a good job since you're already using that motor for propulsion. If you have a dual motor, the front motor will start heating at ~3.5kW, except when it's needed for propulsion. The target battery temp will be close to 40C, much higher than what you need for full regen which is around 21C, or for the snowflake to disappear which is even lower than that. Said another way, supercharger preheat uses the same system as when you preheat the cabin, except it can't use engines that are moving the car, and it will try to warm it too much. If you want to do that, might as well just preheat the cabin.
