For sale are a lightly used (3,000 miles) with zero inclement weather in sunny Arizona N2itive Tartan SX-P2 arms.
These are adjusted to 7mm + to give a near zero rear camber. They will fix your rear inner tire wear. These are adjusted with suspension settings on low on a model S. Only thing you will need alignment is the toe after putting these on as they will give you a toe-in. I did not use the bolts that came with them so they are new.
$900 shipped or $900 installed if you are in the Chandler/Gilbert/Mesa/Queen Creek/Tempe area. You will have to come to me. Itll take 1 hour pending no other issues on your vehicle. These are simple to install if you know what you are doing.
There is someone in Phoenix that will align your vehicle that is recommended by N2itive as well. It is $200 to align last i checked.
