qdeathstar
Completely Serious
The welder doesn’t draw 50 amps.Curious question, for real. You have talked about how the load calculations would be different if it were a welder or an EVSE. I know that the methods are different, but as far as I know, they yield the same number.
It uses 100% value of the non-constant loads + 125% of the constant loads on that branch circuit. It's one outlet with one item, so it's just going to be one of those things on either side of the + sign. The welder you take as a non-constant 50A appliance for 100% of 50A = 50A. A Clipper Creek or somesuch EVSE on that outlet is 125% of 40A = 50A. They are different methods, but I'm not seeing how the 50A or 50A would affect the load calculation differently.
.... if whether the new 50A circuit is continuous or not determines whether you need a new panel or not... then you need a new panel. Lets say it was for a welder... and a year later they got an EV. Think they'll do a load calc on their panel before plugging in?
no, but that is irrelevant. You are essentially saying two wrongs make a right.
Also, like I said the quality of the outlet matters.
