It makes minimal difference in the total charging time. The car can only maintain 250KW charging for a few minutes before it drops down below the 150KW rate. The car charges fastest at a low state of charge, 10-20%, as it goes above that it drops, when you get to 60%-75% you'll see it drop to around 60-70KW. Peak charging numbers are very misleading, they have almost no effect on charge times, it's the charging curve that matters. When you Supercharge let the time to go to the bathroom dictate how long you leave the car plugged in, what you want to do is add enough range to get to your next destination comfortably, anything more than that is wasting time.Again thanks for your recommendations @bjrosen
Just one additional question about charging:
I haven't found any information about this and I am curious if there is:
Most SuperChargers seem to be max 150kW and only a few have a max of 250kW.
Obviously it dictates the charging speed but in regards to the life and performance of the battery should I prefer one over the other?
Thank you @bjrosen.
Today we're taking the car for a trip to Key West. We picked a hotel that unfortunately doesn't have a destination charger (yet). The nearest Tesla SC is like 2 miles away and that shouldn't be too much of an inconvenience I hope.
So it seems that when it is about "topping off" the charge looking for the 250kW stations doesn't make any sense but when you have a car at 10% it would make a difference. Thank you @bjrosen - this is useful information I wish someone at the Tesla store in Palm Beach would have mentioned.
@MaskedRacerX thank you for the ABRP info. It tells me I can go without charging along the way. We will however do a stop at the end of the turnpike for a bathroom break and stretching our legs. The Tesla route planner suggested two stops. Not sure what the point of having the LR is when I should stop twice on a 250 miles trip.
The 90% charging level is marked on the battery image on the charging screen so that seems pretty definite to me. I do 100% an hour before a trip.Thank you @bjrosen.
Here in south FL we don't have much of a traditional winter but I think it wouldn't hurt to do the silicone treatment once in a while anyways.
The level of charging seems to be something where when you ask 5 people you get 5 different answers LOL.
I came across a tweet from Elon Musk stating that if it makes you happy "you'll be fine" charging to 95% all the time and the only reason not to charge to 100% is that regen braking will not work with a full battery and that will cause the overall energy efficiency to be less.
So far our every day driving has been around 220 miles per day (yes, we drive a lot [for work] and that is the reason we got our M3LR).
For daily driving and charging the 80% is OK since at 80% the car still shows a range of 315 miles.
go through the menus, there is a setting for that. Be sure to scroll down on all the screens, sometimes there are more than one screen of options. Click the ? to find out more about the option. And open the owner's manual.Another Q:
Is it possible to for example lane assistant or blind spot warning without engaging autopilot?
My other car gives me audio alerts when I get too close to the lane markings (left or right) without a turn signal and I get a visual warning when there is a car in the blind spot and an audio warning when I set the turn signal while there is a car in the blind spot.
shouldn't be rocket science for my M3 to do the same but I can't seem to get the car to do just that.
