Hi all,
As new owner of MYLR, I have a few concerns about the frunk alignment, of course
- The middle of the frunk hood is slightly higher than the sides when closed and protruding a bit over the front bumper (pictures attached). Adjusting the rubber stopers on the hood doesn't help because if I make the middle go lower and be flush with the front bumper, then the sides will be too low. Seems like the issue is that the latch locking mechanism is mounted too high. Only if the latch lock will be lowered, than maybe the hood can be flush with the bumper when locked and the rubber stoppers can be adjusted then so the sides will be flush too. Worth trying to fix is myself by lowering the latch lock or better using SC? Or maybe not touching it at all as it's normal / common / acceptable?
- When the frunk hood is closed and I'm trying to push on it, it still has some movement down, maybe a half inch or so. It does require some weight and force and doesn't seem loose or rattle-y but definitely not latched in place so unmovable. Same thing as my previous question, is it normal / common in other Model Y's?
