Took delivery first day and passenger window will roll up and then back down 10%. Car passes calibration test 8/10 times. Car reports obstruction of window.
1.Mobile service replaced regulator. Didn’t help.
2. Problem is worse if the window is left cracked open for long and the rubber door seal is allowed to expand further from its natural crushed state when the window is closed.
3. Irvine service center had car overnight and then adjusted glass and door. My door is now 1-2mm protruding than the rear passenger door. But only at the top, the middle is still flush.
During vehicle delivery, a service guy was sitting in my car and reproduced the problem. Then he pushed the window outward with his finger while he rolled it up and it worked. So this corroborates the fix as the window/door probably need to be pushed out just a hair.
4. Problem is now a lot better but not 100% fixed.
My friend also had the same issue but on the drivers’ side window.
At this point, I think I will let the car “break-in” and maybe the door seal just needs to loosen and soften. I feel like taking into service center multiple times for this will just keep fing things up.
