This is what the production curve looks like when the inverter is clipping.How do you know if your system is clipping?
One other non technical question-when does tesla expect payment? It looks like two payments, when is the first one due?
thanks
Just one note, which is that we (and I think some others) had 1/2 due at start but the other 1/2 was due when the inspection was complete - and before Tesla would submit PTO paperwork. Your information may be more current, or it may vary by job/jurisdiction, but just noting that distinction on the 2nd payment in at least some cases.Just had this discussion yesterday with our install scheduler. We were told 1/2 due when they come out to start work, balance weeks later when PTO is issued and you get approval.
That is more than enough as we typically oversize inverters 20% and personally on my home I am over 30% and it is almost disappointing how little I really clip.This is an amazing forum, learnt a lot by reading through here but still have questions!
I have been spec'ed with a 12.24KW system with annual production of 11605 KWh
1. The inverter they have specified is a SE11400H-US. Is that enough without clipping or should I request two inverters?
2. The only document I see in my account is a customer layout. They did a site assessment before drawing this layout. They did send me some drawings to send my HOA but I have not had to sign anything and they have gone to the permitting step. Am I missing something here?
3. The tech drawing they sent for my HOA approval has a optimizer spec sheet, does that mean they will install optimizers on all my panels or only some of them? I will have shade.
I am sure I will have more questions, so thank you for your patience in answering!
RS
Also, maybe its just me, but I personally would never consider having another solar install without having powerwalls, having recently added powerwalls to my pre existing solar install. You dont mention them, but one thing to keep in mind is, if you have solar on your home, and have a power outage, it will not power your home during the outage without some sort of battery storage on premises.
also 11,000 kWh out of a 12kW system seems real low. Unless you live in Seattle
Yes, the engineers figured out how to do that already. The PV panels are designed to fail to continue to produce electricity when there is no matching SINE wave from the grid. However with the installation of such equipment as the Tesla Powerwall supporting equipment, when the grid goes down, the "gear" senses the grid is down and switches automatically to batteries. If you have enough batteries you can operate without grid power until your PV can produce energy again to power your house - that is if you also have enough PV to recharge your batteries.@jjrandorin - You mention that in the case of a power outage the solar production shuts down. I sort of understand that this is to protect public utility workers from unexpected electricity? Assuming this is true, can I not have some kind of automatic disengage from public power when grid power goes off and still produce electricity that I consume within my house? So I would have power during the day.
Then I suspect 0 clipping ever.@jjrandorin - You mention that in the case of a power outage the solar production shuts down. I sort of understand that this is to protect public utility workers from unexpected electricity? Assuming this is true, can I not have some kind of automatic disengage from public power when grid power goes off and still produce electricity that I consume within my house? So I would have power during the day.
solar newbe here... although I have a 10.4kW system with two PW's on order. My installer spec'd 32 PV modules with 32 Enphase IQ 7+ micro inverters.
question: will this system have a clipping limit, given that the IQ7s will individually enable or be shut down?
Also I understand the micro inverters are similar effect to a single large inverter with optimizers on each panel, right? Any thoughts on advantages to micro inverters that offset their increased cost?
Thanks everyone for the helpful advice and education. This set of threads in invaluable.
