I'm not in Canada but being a solar system owner this caught my eye. In my area a solar system is required to have a master disconnect on an external wall that emergency personnel can access to isolate the system. Is what you are describing different from that? You make it sound like each individual panel must be capable of being shut down "remotely", whatever that means. But I find it hard to believe this requirement mean each panel has to be individually controllable.The remote shut off is going to be passed due to the peril to firemen and others. If the house has a fire, and it's sunny out, the panels are live, and pushing power to the inverters/batteries/line. The new requirement will insist that each panel can be remotely "disconnected". This will limit the danger to those who might have to work on the roof, or put out a fire...
That's where it is heading in Canada. Not code yet, but proposed. The thinking is that all of the feeder cabling is still live. The master disconnect would take out the power at each panel via Power Line carrier, or RF. It's going to be a lot simpler if each panel has a string line inverter. I have seen a system, GreenEye/GreenBrain, from Europe, that will do this. I'm sure there are others. They are cost prohibitive currently, and not a requirement. I haven't seen them installed anywhere.I'm not in Canada but being a solar system owner this caught my eye. In my area a solar system is required to have a master disconnect on an external wall that emergency personnel can access to isolate the system. Is what you are describing different from that? You make it sound like each individual panel must be capable of being shut down "remotely", whatever that means. But I find it hard to believe this requirement mean each panel has to be individually controllable.
Most of the Canadian rooftop installations use Enphase string line inverters with arc fault protection in each inverter
Yes micro inverters. The term "string line" is a generic term for an inverter built into the string of each panel, as opposed to one large inverter, which is fed by a group of panels, via a combiner box.When you say string line inverters you do mean micro inverters right? I usually think of string inverters as the one or two inverters in a system and micro inverters per panel like I have.Good to know it's another safety feature we get from using them.
Thanks
