Hi,
I'm looking to buy my 1st Tesla in the following months (Y or 3). I do a lot of reading on the topic but I have a few questions.
1. I read the cold weather may impact the regen braking (mostly if charging level is high). Does that mean that the "one pedal" driving isn't working? Or it only means the energy isn't used?
2. Also, with low temperature in Quebec (can reach -20 to -30 Fareinheit or worse but I don't want to think about it , I planned to heat the car and battery 30 minutes prior leaving. If the car isn't on charge and starts to heat (as shceduled in the app) but I stay home.... will the car heat indefinitely and drain the battery? Or is there a timer option in the app to stop heating the cabin after a while?
3. The frameless windows can be jammed in cold weather and cause issue opening the doors. What is the risk? The glass may break, the micro switch (or electric component) may break, or the door just won't open? Is this type of damage covered by the warranty?
Thanks a lot!
Thanks a lot!
