Most valve stem holes come in a few sizes, with the most common being 0.453 inches and 0.625 inches for snap-in stems. For TPMS valve stems, the size of the hole can be larger for some snap-in and clamp-on holes, but the real problem can be the anatomy of some custom wheels. The valve stem areas may not have the correct size and shape, affecting how a TPMS valve stem seals. Also, some custom rims can have drop centers, barrels and flanges that don’t match up with the original rim or TPMS sensor. But there are some options to address this.
Banding the Sensor
Option 1: Aftermarket Stems and Seals – There are aftermarket stems and seals that can seal stock sensors to custom rims. These can keep the proper orientation and location of the sensor intact.
Option 2: Banding the Sensor – If it is impossible to fit the sensor in the original rim hole, you can attach the sensor with a kit that bands the sensor to the drop center of the rim. These kits come with a metal band and a mounting tab for the sensor. The sensor is attached to the tab using the stock attachment method. When mounting the sensor, make sure it is mounted flat and in the same orientation as it was on the stock rim.
Make sure the sensor is attached across from the valve
stem. Knowing where the sensor is can prevent damaging the sensor when mounting the tire.
Option 3: Looped Valve Stems – This option allows you to mount the TPMS sensor to a mounting hole on the back of the valve stem. These can work for clamp-on sensors on wide truck rims.
Option 4: New Sensors – There are a lot of replacement TPMS sensor lines on the market that will allow you to install a programmable sensor. These have a wide variety of mounting methods, including using snap-in valve stems.
