I have a paver driveway and I’ve started noticing oily stains whenever I parked my MY with the nose higher and the trunk lower.
Sounds weird, but has anyone else noticed anything?
My driveway is wet today, but will post pictures soon.
That should just be water, isn’t it?Are you sure its not just your AC condensation?
I am seeing dark stains on the paver stones that don’t dry off.
I have been reading the posts on TMC. This is my first post. I have been driving my Long Range Dual Motor Model Y since the middle of June, 2020. My Model Y had a similar fluid leak to what you describe. If you can confirm that the color of the oily liquid that is dripping from your Model Y is fluorescent yellow (like a yellow tennis ball) I know what it is. The yellow fluid is compressor oil from your model Y's HVAC compressor. The compressor oil normally circulates inside the compressor line(s) with the refrigerant to lubricate the compressor parts.Are you sure its not just your AC condensation?
The fluid appears to be leaking near one of the front wheels, is this correct? Brake fluid can smell like fish oil.Sorry to open this one again, but it’s started happening to me. And this in a garage I’ve been parking in for over a year without any issues. The fluid is brown. It is slimy or slippery in nature. Not a lot of it. At first I thought it was due to the new epoxy coating, but then it started in a different garage. My best guess is it’s break fluid, but I wouldn’t expect it to be so brown already. I need to get a service appointment scheduled (as I have several items that need to be taken care of anyway).
In the picture you can also see water from the compressor and tire stains..
Thanks! I've got a bit of a cold at the moment, but I would say that's an accurate description of the smell, and the consistency definitely matches that of break fluid. Guess it's time to call service.The fluid appears to be leaking near one of the front wheels, is this correct? Brake fluid can smell like fish oil.
My 2020 Model Y never displayed an error code on the screen.Assuming it is leaking HVAC compressor fluid, should I be seeing some warning/error in the UI?
Is the vehicle safe to drive, perhaps with AC/Heat turned off, while waiting for the appointment?
I drove my Model Y with a slow compressor oil leak for ~ 2 weeks but only for short distances. This was in July so the AC was running to cool the battery and cool the passenger cabin.
How much of the yellow fluid are you finding beneath the Model Y?
