I found an interesting behavior of the battery doing several tests on road trips. The BMS reports the energy stored in the battery on the CAN bus. I compared the numbers right before I left and at the end of a drive. You would think if you have say 60 kWh in the battery before you leave and use 50 kWh driving you would have 10 kWh left. In reality I found that this never happened. I consistently see less available than the numbers would add up to.
Here are two screen shots of the numbers at the beginning of a drive and at the end. 1.3 kWh got lost on the way. Top row is the energy used on the trip. 4th row is the remaining energy in the battery. (I did the first screen shot a little too late when I was already driving hence the 0.11 kWh starting number. It needs to be added the the remaining capacity at the beginning)
I charged the car to 100%, drove for a little over 2 hours and stopped at the next supercharger. The CAN bus tool I use (Scan My Tesla) counts *all* energy used. The missing energy isn't something else that wasn't measured or not accounted for.
So where is the energy lost? I have done this test several times and the amount of missing energy varies a little. Usually between 0.4 and 1.5 kWh. I believe that the energy reported by the BMS when fully (or partially) charged is correct. The energy measured at the end of trip that has been used is slightly lower because of battery internal losses. Depending on how you drive the losses from the internal resistance vary. Electric losses are 4 times higher at double the amperes. So if you drive with a heavy foot you are losing more. The above example was me driving pretty fast especially going up hill at 85 mph hence the rather high lost energy.
In the end its not a lot. Worst case it's 2% lost range. Just thought it was interesting to see those numbers.
