not charging over 90%. 30 amp charge rate, 65 degrees outside. 80 degrees in the car. Any thoughts on why regen would be limited by 5-6 dots? Been happening a lot lately.
The higher SOC the more sensitive it is to temp vs regen. When SOC gets real low Regen starts to come back even when it’s very cold. Same reason SC rate gets limited as SOC goes up.
Temp in the car means nothing.
Overnight temps mean a lot.
It was in the 70’s to day but was in 40’s overnight. And I had a good 8 dots of limited regen at first. Happens all the time. My garage is pretty cool on the concrete floor even when it’s fairly warm out.
My SR+ is the same way.
Yesterday I charged to 90% and the message came on about limited Regen. I swiped the message to the left and that left the exclamation mark in a circle on the screen.Was going to start a thread on this as my SR+ never has full regen when between 80-90%. (That said it is still pretty cool out, 10-15C). Phone support said that’s to be expected with full regen occurring under 80%. Going to try charging just to 80% and see if it’s any different.
P3D-
I can't remember not seing a small number of dots on regen on my 12 mile commute - even with temps in the mid 60s-70s. I usually charge to around 80%
I only mentioned inside temp because about a month ago I had limited regen in the afternoon when it was 75 degrees out and the inside of the car was close to 100 (sitting in the sun). Seems like the high inside temps caused it to go into limited regen? It definitely wasn't a cold issue.
