I have wall charger 240V ..Tesla sets it automatically at 32A
Sigh.
@tampaboyt: Definitions always help. There's two common ways to do Level 1 or Level 2 charging: Either with a Tesla Mobile Connector or a Tesla Wall Connector.
- Tesla Mobile Connectors come in a cloth bag with a zipper.
- It used to be that one got one of these as a freebie with the car (both my SO's 2021 MY and my 2018 M3 came with one). Nowadays, my understanding is that if one is getting a new Tesla, one has to pay for the thing. They're about $250 or so.
- One end of this thing goes into the Telsa charging port. The other end has a cutesy bit of electronics with lights and a socket. Into the socket goes, potentially, a Large Number of possible adapters.
- The adapters come in either 120 VAC flavors (NEMA5-15, NEMA5-20), which are classified as Level 1
- or as 240 VAC flavors (NEMA6-15, NEMA6-20, NEMA10-30, NEMA15-50, etc.) that are classified as Level 2.
- The second digits (15, 20, 50, etc.) refer to the maximum current such the socket can carry. The TMC, though, maxes out at 32A.
- Tesla Wall Connectors, and a plethora of similar products from the likes of Juicebox et al, are typically (although not always) hardwired into a breaker in a breaker panel. The Gen 2 TWC (of which I have one) happens to support such a connection up to a 100A breaker; Gen 3's max out on a 60A breaker.
Fine. The Next Thing which is important: The National Electric Code hath mandated that any heavy, steady load (That's a Tesla) shall not run at any current greater than 80% of the breaker/socket/wire rating. So, this gets enforced in two ways, depending upon the connector:
- Got a TMC? The TMC's electronics looks at the adapter plugged into it and figures the max possible current to report to the car from that. Got a NEMA5-15? Then, max load is 120V (it's a Level 1) at 12A. 12A = 80% of 15A. Got a NEMA10-30 adapter plugged in? Then you get 240 VAC (it's a Level 2) and 24A, 24A being 80% of 30A.
- Got a TWC or equivalent? Then it's the electrician or whoever did the install. On a Gen 2 TWC, one sets a rotary switch. On Gen 3, it's done through a Web UI to the box. In both cases, it's supposed to depend upon the breaker hooked to the TWC. Got a 60A breaker? Then one sets the config/switches for a 48A (80% of 60A) load. Got a 40A breaker? Then set the switches/config, and what you get is a 32A max load. All of these are 240 VAC; far as I know, I don't think it's possible to set up a TWC for Level 1 (120 VAC) charging. As I mentioned, the Gen 2 TWC can support a 100A circuit (80A load),
Next thing: From a charging rate perspective, all the TMC or TWC does is communicate with the car to let it know (a) what kind of circuit (L1/L2) it is and (b) what kind of current can be supplied.
The car itself adjusts the load current. The only thing the TMC or TWC does, electrically, is to provide the connection. On the TWC, it's a blame contactor, the same kind of widget that applies 240 VAC to one's house HVAC system. One can hear it go, "clunk" when it connects and "clunk" when it disconnects.
And that brings up the next point: There's a
reason that the TMC and TWC's have the word, "Connector", in their acronyms. It's because they
connect, they don't actually
charge. The actual charger, the whatsit that's keeping track of the battery voltage and how many electrons are being stuffed into the battery, and how fast, is the
car itself. The car takes in 120 VAC or 240 VAC, rectifies it into a DC voltage, then runs it through DC-DC converters to a much higher, variable DC voltage, that is used to charge the batteries themselves.
Superchargers, "Level 3" or DCFC (DC Fast Chargers) are a special case. Those things put out a
variable DC voltage that bypasses the car's rectifier and goes, pretty much, straight into the batteries. The car tells the Supercharger what the voltage should be through a communications protocol. So, Superchargers probably do deserve the word, "Charger" in the name.
Two more snivveys and I promise that I'm done.
First off, there's a weird thing about the NEMA14-50, the 240 VAC, nominally 50A socket, that one finds in RV parks all over. In the
NEMA universe, there are 15A sockets, 20A sockets, 30A sockets, and 50A sockets, but there are no 40A sockets. As it happens, there's a fair number of electric stoves and clothes driers that need a 40A circuit with a 40A breaker and wire rated for 40A. So, the NEC, in its wisdom, stated that it's perfectly all right to have a 40A breaker, 40A wire, and a NEMA14-50 socket. So long as its labeled. Which means that a $IDIOT might plug a 50A-style load into such a socket which, given Large Numbers of Houses, sooner or later some house or other is going to go up in flames if there's a lot of idiots around. And there's never a shortage of idiots. Or labels that, after 30 years, have fallen off. So, if for no other reason than this, Tesla's engineers can't tell if one has plugged a NEMA14-50 adapter into a 40A socket, in which case 80% of 40A = 32A is safe, or into a 50A socket, in which case 40A is safe. So, Tesla played it safe: There may be other reasons, but 32A on a TMC is all one gets.
Second: As I mentioned before, it's the
car that sets the charging current, always and everywhere. That limit is set for two reasons:
- What kind of car it is. If one has a SR (Standard Range) car, such a car has a smaller battery than a P or LR car. In order to save on costs, SR cars also have fewer charging modules for AC voltage. The modules are good for 16A each; an SR gets two of them (32A max); an LR or P gets three of them (48A max). So, even if one plugs one's spiffy new Tesla into a TWC that's good for 48A, and one's spiffy new Tesla is an SR, 32A is all one is going to get. As I mentioned, older Model S's did support 80A charging, which is why the Gen 2 TWC supported that.
- State of charge. The closer one gets to 100% charge, the slower the batteries in a Tesla can charge without overheating. So, even if one has a M3 LR on a 48A TWC, when one is charging at 95% SOC, one is not going to get 48A; one'll get 10A or so. Perfectly normal. Note that this also shows up with a vengeance when Supercharging; at a 250 kW Supercharger one might actually get 250 kW until the car hits around 30% SOC, at which point the charging rate drops off fairly linearly with the SOC. At 80% SOC, the charging rate is around 50 kW or something. Still faster than L2, but a lot less than that 250 kW at, say, 10% SOC!
Finally: Going back to your comment:
- The "Wall Charger" doesn't compute. I guess it's a Wall Connector?
- If it is a Wall Connector, 32A implies one of two things:
- You've got a 40A circuit breaker on the Wall Connector, so 32A is what you're going to get.
- You've got an SR kind of car, you know, the one with 287-something mile range, and that car limits the charging rate to 32A, no matter what kind of breaker you have.
Having said the above: If you actually do have an LR or P style car, you might be looking at a configuration issue. First, find out what size breaker is connected to your TWC. If it's 40A, then you're fine, stop. If it is, however, 60A, then somebody misconfigured the TWC, and it should be rejiggered to supply 48A to your car. Wouldn't be the first time that an electrician messed up an install.
Last thing, to the OP,
@hippagun: If it's a NEMA14-50 at the campground, that extremely very likely dead lock is a NEMA14-50 socket backed up with a 50A breaker. But the TMC that you're going to hook into said socket is going to do its 32A max thing. Don't bother changing anything with the Tesla, one way or the other, you're just going to get 32A. Which, for the purposes of camping/charging overnight, you'll be doing fine with. Just verify that, when you do start charging, that it really is doing 32A and not some lower value.
TMCs/the cars have been known to drop the charging current when, as the current riseth up, the voltage falleth down. That's usually an indication of a loose wire somewhere, and such things generate heat. Like, a
lot of heat As in, charring things heat. Further, there's a temperature sensor in the plug that goes into the socket; if things Heat Up (also a sign of a loose wire somewhere or bad socket) the car will Save The Day by reducing the charge current to keep things from catching on fire. If any of that happens, try a different camp site and let the owners know. (Which.. they might know, which is why you may have got that campsite
I mean.. There is a theoretical way to get 40A (80% of 50A) out of a NEMA14-50 socket: You'd have to buy (probably used, Tesla doesn't sell them any more) a Wall Connector that has a NEMA14-50 plug on the end of its cable. Or buy a Wall Connector (Juicebox, etc.) from somebody else that has that plug and can do 40A. But that's several hundred bucks, won't fit that nicely into the trunk, doesn't really improve your charging time much, and stuff like that requires a GFCI somewhere, so it gets complicated. Don't bother.
