Don't count on being able to be towed if your battery goes to zero. I went to zero, and quickly exited the freeway, knowing that there was a surface street with 4 miles of downhill that I was going to use to charge the battery. (I will interject that I had an extra mile to get home, but road construction blocked off my exit and I had to continue to the next exit on an uphill freeway). I made the left turn off the exit ramp pointing downhill to start the regen, and the car just kept accelerating. The 12v battery had also gotten so low that there was no energy left to run the regen... I plugged into an exterior 120 outlet at the local AAA and waited 4 hours for the battery to get one mile of charge. The phantom range has to be replaced before the battery will show a mile. If towing was the only way to charge your car and your 12v battery is drained, you probably could jump the 12 volt battery with a 12 v battery in the frunk and jumper cables.
