wiztecy
On warm days here (85-92F) my PEM is always on the last blue bar. My car sits out in the sun all day and I also charge at 30A sometime during the day. I definitely worry about long-term health of of the PEM as it seems to be hot all the time.
I wonder... There's the coolant reservoir right there next to the PEM. How difficult and beneficial would it be to plumb some lines to carry that coolant over into the PEM? I should try to measure the temp of that coolant.
Plumbing the coolant lines to run through your PEM will lower your PEM temps but it will also raise your battery temps significantly. I'm more concerned about my battery health over the PEM health. For the PEM cooling I try to find shady spots and nearby parking garages to keep the PEM and Roadster's temp better managed.
Yes, heat kills electronics but more so the large fluctuations in heat / cold. I think the only feasible solution to the PEM is to get more airflow and to keep the PEM as clean as possible from dust, leaves, spiderwebs, etc so it can run at its best efficiency.
