Hi
@aclosedmind and welcome!
I'll copy a response I used earlier to hopefully explain what is going on today. There is a lot of misinformation and I actually get a little sad when people replace perfectly good UPSes with "new" ones that are more tolerant of frequency variations. Using Eatons addresses the symptom but not the underlying frequency problem, which you're experiencing with other electrical items in your house. You may also notice other devices behaving oddly: motorized equipment (microwave, garage door opener, etc), inductive cooktops, AC clocks, as well as LED lights. What you'll want to do is actually get Tesla to fix your off-grid frequency maximum. Details on that below.
Here is what's happening:
When paired with solar and with no grid connection the Powerwall signals to the inverters that it is full by increasing the AC frequency from the standard of 60hz in the US. Modern inverters will shut down starting as low as 60.5hz after a few minutes and instantly at 62hz. This behavior can be confirmed if your inverters are UL 1741 SA certified, the designation that the inverter was tested and properly shuts down in the time allotted at these frequencies. Tesla, however, has pre-configured Powerwalls to set the frequency to 66hz in this scenario which is clearly too high as at these high frequencies sensitive electronics can misbehave. The best guess here is that Tesla didn't want to risk a non 1741 certified inverter staying up when the batteries are full so the default is something much higher.
If you have a UL 1741 SA certified inverter (almost assuredly your SolarEdge is)
the fix is simply to call Tesla to tell them you have a 1741 certified inverter and have them remotely update your Powerwall configuration to a maximum 62.5hz. This took me all of 3 minutes to do on the phone with them.
Of course this ONLY when the grid is unavailable to dump excess solar power to, any other time the Powerwall will hum right along at 60hz and your LED lights will be happy. Once your maximum frequency is fixed you could use your old CyberPower UPSes again as well during a grid outage and high PV output.
More details here:
My grid outage frequency issue is resolved!
