Kant.Ing
Kanting, when I started this thread, I was on a much earlier version of the firmware (1.17?) which pushed the Hertz level to past 65 to stop the solar inverters from pulling power from the panels. Subsequent releases have lowered that value to 62.9-63.2 (in your case), which most UPSs can handle as 'good' power during that time frame.
When the power goes out, you should hear (if sound is implemented) the UPS beep that it is active for about a second or two as it provides cycles to those important loads until the PW2 inverter kicks in with its own cycles. Then the UPS simply matches cycles as best as possible and again passes through the PW2 power to those loads.
ALL my different UPSs work through this type of event with the PW2 now (I have many critical loads and 8 UPSs...) so you should be safe with whatever you choose.
Thank you for the update and opening the thread. Your info is helpful to me because I always want to provide a reliable power to my computers and don't want my file servers to lose power and end up corrupting data during such events. I will still keep an eye on this, since my UPS has spec'd an input 57-63Hz, and as this seems to be something Tesla firmware can touch, I hope it won't break in the future.
