Appreciate the help, and yes of course I have read the thread. Other than specific UPS suggestions there aren't any actual workarounds to the issue and I haven't heard back from Tesla yet myself. I could have been more clear that my specific question was about the night time situation where the PV is not producing. vlad_kalish had a night outage back in January, but it wasn't a test and he also did not have a way to check the frequency. NinjaVece 's reply shortly after makes complete sense but didn't address the night question directly. NinjaVece also said he started this thread with a much earlier version of the firmware (1.17) and Tesla has changed this behavior multiple times since so even fairly recent testing could already be out of date as 1.34.3 came out here sometime in late March or early April.
So I mostly agree however hasn't it been shown by other folks on this thread that the Powerwall will ramp up the frequency over time if the PV is still producing and then ramp it down to let the inverters come back once the battery has enough room? That would imply that it has the capability of monitoring the input and be smarter about how to adjust the frequency so that the panels don't come straight on as the sun rises or whatever. Naively it could be that it simply does a time based (X hz for N seconds) or Powerwall SOC based frequency adjustments. Regardless, since my inverters are UL1741 certified 60.5hz should be just enough to keep the inverters offline.
@NinjaVece was the 60hz +/- 3hz UPS consideration the only reason you were thinking of 62.9hz as your "steady state" for turning off the PV? Seems to me that for UL1741 certified inverters 60.5hz
should be just fine.
