After a bit of a hiatus, I'm back! We recently moved into a new home and am getting solar installed now. Exciting stuff but I could use the help of the forum for a question that just came up.
New home is in a location where mean maximum high in the summer is 95f / 35c and mean minimum low in the winter is -17f / -27c, has 400a service, pre-run conduit for solar and battery in the basement. We opted for a Powerwall+ system, battery is just for backup. Inverter is physically separate from the actual Powerwall battery which is nice because that limits the amount of back and forth from the basement.
The inverter sticker says the operating range of the inverter is -30c to 55c. That's darn close to the mean minimum and it's likely that we'll have at least some time over the next few years where the temperature will dip below that (record lows are -40f / -40c).
Question is: anyone have experience with the Powerwall+ inverter in colder climates? Does it make sense at all to consider putting the inverter in the (heated and insulated) garage or is it not worth the pain of install and loss of garage wall space?
