After reviewing other threads, I have learned that I am quite unknowledgeable about my 15.33 kW SunPower system.
After pricing out a generator for backup power last week (as recommended last year by my small/family/local solar installer here in Pennsylvania), I concluded a battery system makes more sense for my needs when the grid fails.
Today I located and emailed a Tesla approved and reputable Powerwall installer who will certainly answer my question on Monday but I’m wondering if my system is even compatible with the Powerwall.
Do I need to identify the inverter to answer that question?
All the paperwork for my solar system is at my office so I don’t know the inverter manufacturer but suspect it’s SunPower like the panels.
If the Tesla product is not suitable or compatible, what is the next best option for battery back up?
Here is a photo of the exterior equipment:
While Powerwalls are likely to be completely compatible with your existing equipment, they may not solve your backup issue(s).
When do envision needing backup power? Winter time, when the solar production is at a minimum? When things are overcast due to a winter storm? Summertime, when you need AC? What loads do you want to support? (Laptops and some phones? Or a heat pump/AC and an electric range?) How long do you want to support being off of grid power?
I have three Powerwalls with enough solar to be a net exporter and for winter outages, that's enough for the frugal use for a day or two. (No heaters, just two fridges, an internet connection and gas heat.) The problem with winter outages for me, is that they seem to occur during bad weather, so the Powerwalls don't necessarily start the outage at 100%, but the solar production is down to 2-4% of peak production due to overcast. For you, that might mean getting by on 2.5kWh/day (guesstimate based on a week overcast preceding an outage event, and then overcast for awhile thereafter) of sustainable use for a longer term outage. (I also have some backup generators, but that's a different story.)
I think backup power comes down to what it would take to cut your home usage to bring it into line with what your solar might produce during a couple weeks of winter overcast. If you can't get by on your minimum solar (say my guesstimate above of ~2.5kWh/day), you need a plan B, which may be a generator.
For anyone considering a generator, I think it is worth also considering the frequency that you might need it, and whether a plan C of going on vacation, or moving to a motel / distant relative / an RV makes for a more suitable solution. The cost "per kWh actually used" on a generator can be extremely high; there is the capital cost, the installation cost, the yearly maintenance (filters, oil changes, including biweekly exercise cycles), any service contract, plus the running cost per hour of the fuel when you actually use it. For folks whose plumbing might freeze in a sustained outage, that might be easy to rationalize. Finally, generators function best when they are loaded to 50-100% of capacity, and starting noninverter ACs can be a compromise between enough generator power to start the AC, but not so much that generator loafs along at 10% for the rest of the time. A backup genersgor might reasonably include installing an inverter AC/heat pump.
I think that the decision process isn't simple, and generator sales people and installers aren't necessarily without vested interests in the outcome.
Finally, I would consider whether your backup generator fuel source is to be relied upon (e.g. propane, diesel/heating oil, gasoline, or natural gas). Propane long term storage works really well, but the upfront tank costs can be quite large depending on the generator size and for the duration you are planning for. Diesel can be stored for long periods of time with attention to detail. Gasoline sourcing and storage gets complicated if you plan on storing it for more than a year. Depending on where you live (e.g. Texas, California), an electrical outage for you might also eliminate your natural gas supply.
I think that other vendors of batteries do a much better job of integrating with generators compared to Tesla, which essentially doesn't support their use. (Very limited list of "supported models", and generally only for completely off grid scenarios.)
Just my $0.02, from someone who has gone through the process more than a few times.
All the best,
BG
