  • We are looking for another podcast participant who can act as a lead co-host to join the TMC Podcast. If you are interested in participating please see this thread.
Private Spanish company plans to launch reusable rocket
ecarfan
Moderator
Saw a news story about PLD Space planning to build a “reusable” rocket so had to learn more. Turns out it’s a sub-orbital vehicle “designed for microgravity research and technology development” with a 1,000kg payload capacity. Each flight will provide 3-4 minutes of microgravity time.
I have to wonder if there is really a market for such a vehicle.
Here’s a diagram showing the launch and recovery. A parachute will come out of the tail end of the rocket as it descends and it will land in the ocean nose first, then be recovered for reuse. Points for originality.
Reactions: petit_bateau
Since most of the weight will be near the rocket engine at the bottom of the rocket,
how would it be possible to keep the rocket vertical with the top below the heavy bottom ?
Hower, this recuperation was previously used by NASA:
The Space Shuttle Rockets Falling From Space
Every time NASA launched the Space Shuttle, two 45 m (149 ft) tall rockets called the Space Shuttle Solid Rocket Boosters (SRBs) were used.
The Space Shuttle's Solid Rocket Boosters provided thrust for the first part of the ride, and were then jettisoned
at an altitude of around 46 km (148,000 mi). They landed with parachutes and were then recovered by ships and refurbished for reuse.
Reactions: MitchMitch
ecarfan
Moderator
Because when the chutes open the rocket is descending nose down and the chutes are attached to the end that is “up” from the nose.
Good point. Thanks for posting that photo. I had known the shuttle boosters were reused but had never seen a photo of them landing in the ocean.
Drifting off topic, but the SRB onboard video was equally good. Quite a dynamic ride and impact on the ocean surface.
On the video, from 5:18 to 7:15 it seems that the booster was reignited?
But it seems that the back of the booster was not always toward the earth,
so did reigniting the booster could really help reducing its speed?
Electroman
7,668
11,686
TX
I don't think it reignited. The booster hit the upper parts of atmosphere and the remnants of the fuel which was still smoldering is what we see as the embers were getting scattered due to moving through air.
Also it was a bit odd to see the booster still moving at more than 2k miles per hour, but tumbling end-on uncontrollably.
I wonder what would be the terminal velocity speed when the parachutes of the booster get open ?
Electroman
7,668
11,686
TX
What was also interesting is if you look at both the boosters, they were tumbling exactly in synch with each other.
There was no reignition, that's just bits and pieces of the remaining solid propellant burning and smoldering. No real usable thrust or propellant at the point they separated from the rest of the shuttle stack.
