Pull on incidence of replacing either lower compression bushing or front upper control arm (ball joint noise)
Have you replaced either of your front upper control arms or lower compression bushing?
  • We've replaced one or both front upper control arms due to noise (with OEM part)
    Votes: 10 45.5%
  • We have replaced one or both compression bushings (with OEM part) due to failure/noise
    Votes: 2 9.1%
  • We have replaced both upper control arms w/aftermarket part (not due to noise for camber control))
    Votes: 9 40.9%
  • We have replaced both compression bushings with aftermarket part for better handling/braking
    Votes: 7 31.8%
  • We have not replaced any front upper control arm.
    Votes: 2 9.1%
  • We have not replaced either lower compression bushing
    Votes: 7 31.8%
  • Total voters
    22
dfwatt
Best Car Ever
Sep 24, 2018
4,115
6,270
FL
Now that we're getting into our fourth year of ownership on the cars we are getting some funky suspension noises. Most of these appear to be related to two issues where Tesla's part durability is suboptimal. Wondering how many people have had to replace either the front upper control arm typically due to ball joint noise, or the compression bushing on the curved lower control arm in the front? Those appear to be the two most vulnerable components in relationship to wear and noise. Please note that the compression bushing is different from the lower control arm bushing that frequently is replaced with the very fine Mountain Pass spherical bushing (by folks seeking to gain better steering feel). The compression bushing is the horizontally oriented large bushing on the curved lower front suspension member with a ball joint on the other end and aftermarket parts for this part typically allow you to gain caster adjustment and better control under extreme braking loads. You have two responses to give about whether or not either of these have required replacement under warranty or by Tesla, or whether you have swapped them out for aftermarket parts obviously at your own expense. Thanks in advance!
Both of our cars have now had both upper control alarm Ball joints replaced. Both also have MPP's fantastic front lower control alarm bushing but neither car has the compression arm bushing/adjustable caster
