When using dragstrip mode and doing a launch control, if you press and hold the brake, do you have to mash the throttle or can you slowly press the throttle in while pressing the brake? If you do it slowly, do you get the "both pedals pressed, motor power reduced" error? I do and it makes me hesitant to press all the way as the car is already lurching forward against the brakes.
