Some days ago I came across a video about someone who was inspecting his radiator
So that made me wonder, how dirty is my radiator. I bought this Tesla 2nd hand and when I replaced the cabin air filters there was like a ton of leafs and dead bugs in it.
The car has 65.000 km on it and it is a 2019 model 3.
Since it is winter right now and I dont supercharge alot I dont really worry much about the coolant part of the car.. but it will get summer eventually and I will supercharge one day.
So i let the car run and the front grill opend up and I took a look inside, just a few leaves and a rock where lying on the bumper infront of the radiator.. but I did not see a lot of debris. Of to a good start.
So I removed to interal frunk and managed to slightly open te radiator housing / duct and between te 2 radiators and behold, there was like a ton of cooked up debris in there.. like litterly stuck. I guess it would have made the coolant part of the battery pack a bit worse. It was a lot worse then on the video displayed there.
I managed to get a long flexible soft stick and poke it around a bit between the two radiator (be carefull not to bend the radiator fins), after poking it around I flushed from the top down with water. Still alot of debris would not budge at all....
Anyone know how to remove the plastic housing so I might be able remove or move the top radiator and give it a good clean with a soft brush?
I might be overthinking things but isent this a big design flaw that there is no way for the debris to get out from the ducting?
It is basicly a closed ducting and everything getting in there is bound to stay there forever... stuck between the two radiators to rest there for all eternity.
