Sentry activation is minimal and no 3rd party software.
It's not about how many times sentry is triggered, it's the very act of it being on that keeps the computer running and the car from going to sleep. If I remember correctly, some users suggest it could use about 1% of your battery per hour to have it on.
Obviously since different models and trims have different battery sizes, that's just a ballpark.
You think that could be doing it?
The heat could definitely be a major contributing factor. If the A/C is kicking on every 15 minutes to keep the car cool, that's going to cause additional demand on your battery.
My recommendation is to test this yourself. One night before you go to sleep, turn off cabin overheat protection, sentry, and smart summon if you use it. Park in the garage if you have one. Don't plug the car in overnight, and note the state of charge before you go to sleep... then check the next morning to see if you lost anything. I bet there will be very little (if any) vampire drain. Don't forget to turn those things back on the next morning if you need them.
Parking in the shade is good for *every* vehicle if possible.
That's not to say vampire drain doesn't happen sometimes. There have definitely been cases where the software caused vampire drain, but Tesla fixes those things and you just have to wait for them to push those fixes.
I'm not an electrical engineer, but from reading in the forums it seems like failing batteries tend to appear as an inability to charge and/or an inability to drive at all... I don't recall drain being a symptom of battery failure - just a symptom that something is using the energy.
