My 12V battery is tucked away, prior to the "right behind the frunk" 12V battery move. I have a single motor car, Aug 2013 build.
How to get and remove the battery is well documented.
My idea is to relocate the negative cable so that it is much easier to unhook the 12V electrical system.
I would probably keep the battery where it is, but put the other end of the negative cable near the fireman's loop, or close by, under the passenger side frunk trim.
Where is the other end of the negative battery cable?
Where does the other end of the positive cable mount to?
What is the bolt thread on the stock battery?
I am also considering building a tray, and moving the battery to the "new" location, behind the frunk.
Thanks
Thanks
