So I'm a problem solver so I just figured I would take a look at it and figure it out.
Heres how you do it
1) Open your door.
2) Locate where the trim meets the door frame
3) Gently, but firmly lift and work your way down until you can remove the trim.
Putting it back on is basically the same in reverse. You line up the trim with the frame, get it on the rail, and start pushing firmly down.
Hopefully this helps someone in the future!
