Roadster 1.5 wiper arm broke
Discussion in 'Roadster' started by pgwoosley, Nov 16, 2014.
Tags:
  1. pgwoosley
    pgwoosley Member
    The wiper arm on my 1.5 Roadster broke about 3/4 of an inch from the attachment to the shaft. The reason is completely unknown (non freezing weather).
    Anyone else had this happen or have any ideas?
    Anyone have an extra arm or know of any other cars this arm is used on?
  2. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    #2 dhrivnak, Nov 16, 2014
    This happened to mine as well. I think it was $75 or so for a new one. You may need a gear puller to get the old base off. But those are inexpensive or are often rented free of charge from Advanced. I was able to repair my old one with JB Weld and I can send for $20 if you are in the states but you may be like me and prefer a new one as I am not sure how JB Weld will hold in all conditions.
    EDIT - Upon inspection I did not keep my "repaired" wiper arm. While it appeared solid I had visions of a heavy rain on a dark and cold night with it failing again. While JB Weld is great stuff especially when pins are added I doubt it is stronger than a new one.
  3. pgwoosley
    pgwoosley Member
    See PM
  4. wiztecy
    wiztecy Active Member
    The Elise will fit, but for some reason ( I think I know ), the wiper arm is slightly different. The "[" looking section of the arm is longer for the Roadster, the Elise is not as aggressive. It will work. I think the "[" part being aggressive on the Roadster somehow adds more force down on the windshield for better coverage and wiping action when the Roadster is moving at higher speeds.
