Roadster Touch Up Paint
Discussion in 'Roadster 2008-2012' started by wiztecy, May 31, 2012.
Tags:
  1. wiztecy
    wiztecy Active Member
    How do Roadster Owners find the right color touch up paint? Is this something you go to Tesla about and do they gouge you? Or is it trail and error at the local automotive shop?
    I went to the autoparts store, viewed all the cap colors for the mini brush type paints all to find when I got home the color was way off. I'll head back and see if I can open other ones so I can make a better judgement. They're pretty cool there.
    Has anyone found a paint code/manufacturer that's worked for you. If so can you please post your car color and the company / part number of the touch up paint.
    For me I'm looking for the "Radiant Red". If I find one I'll post the info here. Thanks!
  2. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I had to get mine mixed at a local shop. They had to find the Lotus European color as the could not find under Tesla. I doubt you can find a ready mix version. I think i paid about $30 for a small amount of touch up paint.
  3. Nvbob
    Nvbob Roadster 1256
    Just east of Lake Tahoe, Ca.
    Tesla has touch up paint. $14.95 We got one when we did our annual a couple of weeks ago.
  4. wiztecy
    Thanks for the info, great help!
  5. slcasner
    slcasner Active Member
    Sunnyvale, CA
    The touch-up paint that Tesla sells for a Radiant Red car has Lotus branding on the tube and color designation "Canyon Red".
  6. jordanthompson
    jordanthompson 2018 P100D Model X
    Satellite Beach, FL
    Has anyone had any luck actually using it? I imagine its not easy to use. I have a couple of dings I'd like to touch up, but am afraid it will look worse than when I started. I'd be interested to know how you went about using it.
  7. wiztecy
    I'm really good with ding repair let alone when someone has keyed a car.
    Had a tire slasher try to puncture my truck tires but he didn't know I was running commercial tires which have steel belts on the sidewalls, not nylon/polyester to handle my truck camper, motorcycle, and fishing boat I take on my camping trips. He couldn't get past the 1st front tire, keyed the truck down the side (front fender was down to the metal) and tried puncturing the back tire with his full force. The knife folded in and cut the guy breaking the blade off. That night he struck 50 cars. When my friend called I knew he didn't get past my truck so I did some good investigation... what would a dumb tire slasher do as for leaving evidence? Cut himself. So I looked at my wife's car tire that was slashed. Blood. Then I said where would he cut himself. My truck. So I looked and there was the bloody blade right below my truck tire and the truck tires still filled with air. So I called the cops and told them they missed something. They came and sent it in for DNA. One month later they had a match and also found the guy with a dagger, a hand gun, and he had previous felonies. Glad to get that guy off the street.
    So getting back to touching up. Paint can be forgiving, such as with touchup. So with the keyed damage I used an orange glaze putty (they sell it at autoparts stores) to bring the surface even with the paint. Then I found matching paint to my truck's color and began over spraying with very quick light bursts of the spray can over the keyed area. I then allowed it to dry very well. I came back over with very very fine wet sand paper to start the blending process. I then used rubbing compound followed by polishing compound followed by a good buff with polish. And back to new it was. Can't even tell the truck was keyed. The two front fenders were just replaced on my truck and freshly painted too. Go figure. Only the front fender had the deep scratch, the rest of the truck I pulled most of the damage out with rubbing compound since it didn't get down to the primer.
    So tips on touch ups. Practice! My friend just talked to me about repairing road chips, he said his trick is to NOT use the little brush but rather a Q-Tip. He then said he uses a piece of paper with a small hole about the size or a little bigger than the chipped area. He then dabs the Q-tip with paint on the paper that has the hole which is over the chip area. He then removes the paper and allows it to dry for some time, he said a day. He then comes back and uses a really fine wet sandpaper (that's wet) to start the initial buff or to bring down the high spot. Then buffs it with a little polish.
    I haven't tried that but I'll give it a go. I'll practice on my truck 1st then move to the roadster. I've alway's used a quick dab with the touchup brush and no paper. I would then allow it to dry and use rubbing compound or very fine sandpaper to buff then I do a small buff job with polish. Just don't add too much paint and again practice on something until you get the right results and feel comfortable. Then move to the roadster.
  8. jordanthompson
    Satellite Beach, FL
    Wow! You should be a COP! good for your for helping catch the b*st*rd!
    I like your friends approach. Sounds like you don't need specialized painting equipment or too much practice. I'm generally pretty good with my hands, and that method sounds like something I can't screw up too much! I need to get the touch-up paint first. Tesla is coming back to upgrade my A/C fan shroud and replace my mud guard - I'll have them bring some brilliant yellow when they come.
    Thanks very much for the tip!
  9. slcasner
    Sunnyvale, CA
    The key idea, as wiztecy noted, is that you need to be ready to take some paint off after the right amount of drying time -- when the new paint is still soft relative to the original paint. That's because the problem with touching up is that in order to fill the ding you also have to get some paint on top of the original paint around the ding. The techniques described are to minimize that, but still you need to go back with wet sandpaper or buffing compound. Check out Dr.ColorChip which is a kit of paint and buffing procedure designed to address exactly this problem. It was recommended to me by a local detailer, but I have not tried it yet. They don't have Tesla listed in their color selection menu, but maybe using the Lotus equivalent would work.
