That's what I'm claiming you're doing with the FSD description.
Right- you are, again, claiming something nobody ever actually said.
Not sure why you keep doing that other than you know you have no actual argument to make so you have to invent strawmen instead?
I don't know why I keep having to mention this, but Tesla never mentions or references the levels in the description
Nobody knows why you keep mentioning it since it's not relevant at all.
I can describe the crime of murder in the second degree without using the word murder for example, but you can then look up the requirements for murder in each degree and determine the actual crime I was describing. Same with many many other things where you can describe a level or capability of a thing without using a specific word that might define that thing.
This is not a hard concept but you somehow get that completely wrong too.
Tesla is a describing the planned capabilities of their system.
If you take that description, and look up the SAE levels, you find that the
minimum level that fits their description is L4.
Somehow you get lost, badly, between those 2 sentences over and over again.
. The description is EXTREMELY brief, as it relates to AUTONOMY.
And yet has all the info needed for what I just explained above, assuming you actually understand:
What they said
and
What the SAE levels say.
The only real portion that relates to AUTONOMY is basically ONE sentence about "action." You seem to be caught up in ONE WORD and say it must mean level 4 because NO ACTION = NO SUPERVISION.
This one you get even
more wrong.
Not even L3 requires "supervision"- it requires being prepared to take over when prompted-
on every drive you take. That is a DIFFERENT action than the supervision actions folks using the current L2 FSDb system must engage in (they ALSO have to be prepared to take over at any time, but also have to do additional actions on top).
Regardless of which, requiring ANY action violates what Tesla actually wrote, regardless of what action that is.
And, again, the
minimum SAE level that requires
no action of any kind is L4.
If you are describing a design intent of a system that
can (even if it doesn't do it 100% of the time) do a complete drive with
no action required of the person in the drivers seat, you are
literally describing an L4 or higher system per SAE
Even if you don't use the words SAE or L4 when describing it.
You've held onto this belief for so long that you don't even know how to break out of it.
Because it's factually correct.
Refusing to understand facts seems to be a big issue with you.
Let me show you something, the SAE levels is a COMPLEX definition. That's why I keep pointing out that it's a 30-page document! You have to read it MULTIPLE times to really understand it!
Maybe try reading it even once and get back to us?
If you did you'd realize you were wrong about this entire discussion, and admit you can't find a single thing in there that disagrees with anything I've said.
(If you COULD find such a thing, you'd have cited it--- instead you keep making up strawmen instead of making up a valid argument)
SAE J3016 is so complex it is difficult to get everything right, even for me.
CLEARLY!
If you see something that is incorrect please let me know
Literally your entire argument is incorrect.
Anything below L4 in SAE requires action by the person in the drivers seat on every drive using the system. The chart is a summary that shows you, circled in red, the action required with every use of the system at L3. Looking to the left you see even more actions required at lower levels.
Tesla said their system will be capable of drives requiring no action.
Thus the system can not be L3 or lower. The lowest level their system could be under SAE is L4. Possibly L5 but THAT we lack enough info from Tesla to determine.
That's it.
That's the entire argument.
You've wasted pages of posts failing to grasp it, providing literally nothing to actually dispute it, and making up thing after thing nobody said to debate instead.
