Sourcing interior light fixture
Discussion in 'Roadster: Technical' started by ravng, Mar 15, 2016.
  1. ravng
    ravng Member
    Norway
    Hi guys.
    Does anyone know of a source for the interiour light? Is this the same as for the Elise?
  2. wiztecy
    wiztecy Active Member
    What happened? Is it missing or just one of the clips broke? If a clip broke just run a loop or two of black electrical tape around the edges and put it back up, it'll hold perfectly. I broke mine putting in the LED, the LED runs cooler so no worry about melting the tape or anything like that. Besides the tape is on the edges, not the top where the heat is most.
  3. ravng
    ravng Member
    Norway
    Broken clip when putting in LED :)
    But it has also been very "loose" in switching between modes, so I guess the previous owner has been a bit hard with it or something.
    Good tip about tape, but I found a cheap Elise light on ebay. It looked identical on the pictures so I bought it, so I'll see if it fits, if not then I go the tape route.
  4. Botbldr45
    Botbldr45 Member
    Sedona, Az
    Are the clips on the end of the fixture or the side?
  5. wiztecy
    The Elise / S2 version does appear to be the one as seen in the pic below. It appears its used in other cars too:
    Lotus Exige / Elise courtesy light: donor car?
  6. ravng
    ravng Member
    Norway
    I can confirm that the Elise version is the same as Roadster.
  7. rudholm
    rudholm Member
    Los Angeles, CA
    Broke the clips on the connector side of mine this evening putting in an LED bulb. I went through the same thought process of "oh crap, I bet Tesla doesn't have replacements!" and then later "oh wait, I bet this is a Lotus part". A little Google Image Search and I found my hunch was correct. lotuspartsonline.com has them for $67.53 plus shipping. eliseparts.com has them for £52.62 plus shipping.
    BTW, this is the bulb I used: https://www.amazon.com/gp/product/B01LYEZPFC/ I got the 3000K but they also come in a higher color temp (they don't indicate the color temperature but it looks like daylight white). I prefer 3000K for nighttime illumination. I hunted around for a while and this is the brightest wedge-based bulb that will still fit in the fixture. I use them in my landscape lighting and they've been great.
    Now let's see if I can upgrade the weak trunk light with a nice LED bulb without breaking that fixture, too...
  8. petergrub
    petergrub Member
    Phoenix, Arizona
    That bulb is far easier to replace. I have done so twice using 41mm LED festoon bulbs. Though, a 39mm would fit better as the 41mm I installed didn't go in too easily.
    Also, check the clear plastic cover for warping. Those incandescent bulbs get really hot causing the plastic cover to droop and sometimes holes to burn in the black housing.
