I don't think astronomers should complain. We are talking about a few Starship - 2 or 3 at max - in LEO at anytime, compared to thousands of Starlink satellites.
Hey, astronomers are people too.
I think astronomers are only going to complain until telescopes start getting built on orbit with Starships. Those things are going to be so large that astronomers will be gobsmacked into silence.
Perhaps the Depot Starship not only carries liquid fuel, it should also have the rigs to create LOX from say liquid water, using power generated from Solar panels... just a crazy idea.
I was curious enough to do some math.
It takes 53 kWh to generate 1 kg of hydrogen and 8 kg of oxygen from 9 kg of water. So if you have a 53 megawatt array, you can produce 1,000 times that per hour. Per week, that works out to 168 tons of hydrogen and 1,344 tons of oxygen. Usable amounts for spacecraft.
Of course, that's a monstrous array suitable only for a big orbital fuel depot. In contrast, the ISS arrays generate around 100 kilowatts. So I'm talking about something
500 times larger.
If you devoted all of the ISS power generation to hydrolysis, in a week you'd generate 316 kg of hydrogen and 2,528 kg of oxygen. That's why you need a such a large array.
Once you have your monster depot, you switch to hydrolox engines for near-Earth operations so that you take full advantage of the byproducts of electrolysis. Interestingly, hydrolox engines run hydrogen-rich, so you'd be accumulating excess oxygen. That oxygen could be used for air, or even for gas thrusters. "We have so much oxygen, we're throwing it away."
Note that if you go hydrolox, you can draw on your propellants for power generation via a fuel cell when solar isn't available. Apollo did this in the command module.
Certainly transporting water around would be a lot safer than transporting hydrogen or methane.
One downside to solar cells is that they're massive and they degrade, so you'd have to replace them at intervals. Bleh.
Here's a company doing hydrolysis for hydrogen generation using solar collectors and smaller devices to perform the actual hydrolysis. They can generate a kilogram in 16 hours relying on light collected by a 7 meter wide parabolic dish. That's 16 hours of production time. On orbit, that could be continuous (barring limits on the devices due to heating, etc).
Researchers pioneer a system to make 500 grams of green hydrogen per day
spectrum.ieee.org
The 7 meter dish is 38 square meters. To get a kilogram
per hour, that would be 615 square meters. To get
a ton per hour, that would be 615,000 square meters, or a single dish 884 meters across. You'd actually use many, smaller dishes, but that's the scale involved. It avoids the problem of solar cell degradation, but I assume that the reflectors would degrade as well. Perhaps they could be polished/refurbished on orbit. It's not a very advanced technology.
This system also generates heat, and you'd have to do something with that. You can get some more power with Stirling engines, but eventually you need to dump it, so you also need big radiators.
Green hydrogen is a tough nut to crack, but I'd say well worth the effort.
