First, I would like to propose to the forum admins that a SpaceX subforum named Starlink might be in order. Maybe even a top level forum with subforums for "installation", "experience", "mods".
Anyway, my question is best method to extend the vertical pole that extends from the Long Wall Mount (Starlink)...
I put a micrometer on it and it seems to be pretty close to 1.5" OD (outer diameter). My simple effort was going to be a Lowe's trip for some 1.25" rigid conduit (which has an actual OD of 1.6") and an 1.25" coupler or two. Likely just cut the Starlink vertical pole in half and insert my extension. I need an additional 24".
I'm not opposed to purchasing the Ground Pole Mount if the upper portion could be used for this need, but it appears to be a LOT thicker pole...
... likely to account for the additional length to maintain rigidity.
Thanks for any thoughts.
