I am a novice at this and don't know the basics. Can someone explain how streaming works in these cars? I have a 22 M3 LR with premium connectivity.
I'm not blaming the car but I would like to understand the 'mechanics' of streaming so I can better understand any anomalies I come across.
Over the past 12 months, on a route I frequently travel, there is a half a mile section of road where I sometimes lose any song I'm playing. I try something else but all streaming stops. The bars on the signal strength don't seem to change. I have also lost the google map a couple of times but that doesn't always happen when the music stops. Then there are times when everything works well at this same spot. I even took a test drive in a new M3 standard range and the same thing happened at the same place.
I suspect some type of electrical interference. The area is mostly residential and the road passes through an intersection that contains the usual small businesses; 7-11, Starbucks, Bank, Hardware etc. All of this is in a large, population dense suburban area with extensive cellular coverage.
