Could be wrong, but that looks like it is significantly over the weight limits for the hitch.When moving I used my X as a moving van. Putting a deck box on the trailer hitch tray allowed extra carrying space.View attachment 335854
Hitch vertical limit is 120lbs according to the manual I'm reading and all the other info I've seen. And note that's 120 lbs when using an accessory carrier like a bike rack. You have to take torque into the account, and that deck box looks to be farther out than a normal bike rack which would impart significantly more force on the hitch.Hitch vertical weight limit is 500 lbs.
The tray is light weight aluminum and I mostly carried bulky but lightweight stuff in there. (Blankets, pillows) Maybe 100 lbs max. Even put the heaviest stuff in the front of the box to minimize the lever effect. Really could not tell it was there.
Was interesting to turn on the backup camera and watch it trail behind. It was rock steady.
Amazing just how much capacity the model X has inside. I even stuffed the frunk with some books and heavier stuff to balance the car. The air ride suspension functioned great in keeping everything level and controlled.
Does it matter though what the hitch says it's rated for (serious question, not being snarky)? It would seem the strength of the frame/attachment points on the vehicle is the only important thing. The hitch itself could take 1,000lbs, but if the Model X can only handle 125lbs due to the way the hitch attaches to the vehicle, it doesn't really matter. Could be wrong, not an expert.My aftermarket hitch has a tongue weight of 750 lbs and a 5000 lb tow capacity.
Because it is manufactured for a specific make/model of vehicle and specifically "is rated" for that exact make and model car or truck that it is to be bolted up to.Does it matter though what the hitch says it's rated for (serious question, not being snarky)? It would seem the strength of the frame/attachment points on the vehicle is the only important thing. The hitch itself could take 1,000lbs, but if the Model X can only handle 125lbs due to the way the hitch attaches to the vehicle, it doesn't really matter. Could be wrong, not an expert.
