I have a ham radio connected to the trailer brake outlet (exposed behind the driver-side outer wall carpet.). This outlet provides 15.1 VDC and can support up to 20 AMPs (per spec). I've used this port for years on my 2017 MX without issue. However, on my 2023 MX, the outlet turns off intermittently. After a few seconds, it turns back on as if the vehicle is sensing an overload. The radio was transmitting on high power, but it does not draw more than about 8 AMPs. Is there something else at play? Is that circuit also feeding other devices? I don't have anything else connected to this low-voltage circuit. My additional concern is that if this trailer brake system cannot support low-voltage moderate to low-current draws, what will happen when someone is towing a trailer and this circuit shuts down?
Ideas?
Ideas?
