Getting ready to trade my M3 and need to get back to original equipment. I am in the process of reinstalling OEM dampers using the the OEM top hats from Redwood Coilovers. Having trouble with the alignment so that the 3 top hat bolts are in the correct position that the LCA lines up also. Once the spring is uncompressed, the top hat can’t be rotated to adjust the alignment. On the coilovers the lock ring can be loosened and the shock body turns. Not so with OEM dampers.
Anyone else have experience with this?
